Drivers door won't lock/unlock with fob
Brad20v
Hello everyone
I'm hoping someone can steer me in the direction to fault find my door issue on AWD .
When using remote,/fob , drivers door won't react, all other doors work. If i sit in vehicle and use the door lock/ unlock button....same same all but drivers door.
I can however lock and unlock via the key, and this also controls the other doors too.
I'm thinking the motor/solenoid in door, but am yet to remove door trim.
Thanks
Did you check for blown fuses?
I suggest checking all fuses related to BCM and also the keyless module
Brad20v
No I have not yet , I would think it's more than a fuse, as the others all work.
Thanks
Brad20v wrote:No I have not yet , I would think it's more than a fuse, as the others all work.
Thanks
yes,but sometimes lack of some power feed to BCM can cause strange things beside it's easy to check compared to the next steps ;)
Performance Benchmark_20200921.png (27.02 KiB) Viewed 4388 times
Brad20v
True that, I will check today
Thanks
Brad20v
I checked all fuses on the 3 fuse boxes, nil faulty found, guess I remove door trim and have a test in there .
chazyouwin
Did you ever resolve this issue? I have the same problem. Instead of unlocking the driver door with the fob or button in the door handle, I get a different style of beep and nothing mechanically happens. Started happening yesterday. Can get in any other door and the trunk also works with the fob and proximity.
chazyouwin
Just ordered https://www.megazip.net/zapchasti-dlya/ ... 5057L35000 door latch actuator. My problem is not exactly the same as the OPs, as my lock only will not open using the remote/handle button/indoor switch. It locks perfectly however using the remote/button/indoor switch. Just the unlocking is an issue.
I have had the door lock motor go bad before. You need the latch assembly . I'd go used . I do have one for $40 +shipping but you may want to see what's available near you. Good luck.
