Need Help with Water Pump
sethseretseth
Hi, I am an owner of a Suzuki Kizashi 2013 2.4L CVT AT and I'm in desperate need of help on where I can purchase water pump set for my Kizashi. I have looked up in megazip.net and other websites but there's no luck. I hope somebody can point me to the right direction. I might need transmission gear sensor as well but that's available in megazip.net, but a backup option won't hurt. Thanks guys!
Hi,
17400-78894-000 is discontinued by suzuki but a new part number is available:
17400-78895-000
but to be sure try to confirm with your local dealer.
I use amazon for this water pump wps800 . Its a very good brand. You may have to bevel the water pipe hole slightly to funnel aged oring back in . $42 . On the output shaft speed sensor, use this application 2010 Dodge Caliber. It uses the exact same sensors. I will say the Kizashi sets a code for this sensor when belt slip is detected and more likely your problem.
rohanahmed
sethseretseth wrote: Wed Mar 19, 2025 10:06 pm Hi, I am an owner of a Suzuki Kizashi 2013 2.4L CVT AT and I'm in desperate need of help on where I can purchase water pump set for my Kizashi. I have looked up in megazip.net and other websites but there's no luck. I hope somebody can point me to the right direction. I might need transmission gear sensor as well but that's available in megazip.net, but a backup option won't hurt. Thanks guys!
were you able to resolve the heating problem?
