Looking for Roof Rails for 2013 Kizashi
If you really want to sell them you will get more attention in the classified section.
Probably include a price and a general location as well.
Looking for some guidance...if I was to buy the Yakima rails on Amazon, do you think this would come with everything I would need, including the fitting kit?
I just select the S26 - 2 bars choice?
Thanks,
Frank
Thanks,
Frank
2007 Mazda 3S GTS
2004 VW Passat
1997 Nissan Pathfinder
2007 Mazda 3S GTS
2004 VW Passat
- Speed_Racer
That looks like it has everything, except I can't tell if it includes the hardware that you would use to bolt to the Kizashi's integrated roof mounting points (the bolt sticking up that I drew an arrow to).
You would need four of those, they mount with two bolts to the roof of your Kizashi. The rack feet slide over it, and then you tighten the red wing thing to secure.
And be sure to GREASE/LUBE all mounting points. Apparently they are prone to rusting in salty climates.
- Speed_Racer
Sorry, the image must not be appearing on your end. Can you see it if you click or copy/paste the link below?fjroman2 wrote:Speed_Racer...where is the drawing you are referencing?
http://s9.postimg.org/hmgxrip5r/Capture.png
