It also does it's best not to let you lock the fob in the trunk.KuroNekko wrote:The Kizashi's key fob works as a Passive RFID (Radio Frequency Identifier). The fob and the car are communicating with each other when they are in range. Basically, if the key fob is in certain areas in or around the car, it will allow or prevent certain things. When you have the key fob within 2 feet or so around the outside of the doors, you can unlock the doors by pressing the button on the front door handles. When the key fob is inside the cabin, you can press the start button to turn on the engine. This also works to prevent you from locking yourself out of the car. The car knows the key fob is in the cabin so it overrides your action to try lock the door from the outside when the key fob is left inside the car.paininthenuts wrote:Right, I have a question. Apparently no car with keyless entry can determine whether the key is inside or outside the car. By mistake I just left my keys in the cup holder, closed the door and tried to lock the car using the button on the door. It wouldn't lock, and I just got a single long beep, WHY ?
It's actually a great system that makes locking your keys inside the car nearly obsolete.
However, this is all assuming the key fob works properly. Low batteries can cause range issues and may cause the RFID system to malfunction.
What if you were to lose your Kizashi?
2011 Kizashi SLS CVT (silver)
2005 Honda Odyssey
2005 Honda Odyssey
I thougth that was a British and Aussie thing.Yes, they are very clever. I normally carry mine in my right pocket, but the other day the fob was in my left pocket. As a result the car went backwards
2005 Honda Odyssey
2005 Honda Odyssey
They are growing in popularity and even preexisted the Kizashi (the Lexus LS is an example) but I've always thought the Kizashi's was unique because of the shape and size. However, it kind of always looked familiar to me and I couldn't grasp why until I read one review on the Kizashi that revealed its design origins. Can you guess what that was? Here's a clue:SamirD wrote: What I find interesting is that the rear exhaust finishers are almost identical to the Kizashi. I've actually seen these on a bunch of cars now, especially the newer models by GM (Impala, Regal).
According to that article, one of the chief designers of the Kizashi was a former Suzuki motorcycle engineer and he gave the exhaust finishers some of Suzuki's motorcycle influence. Hence, the shape and size resonates with motorcycle exhaust designs. Pretty cool.
Amongst many of the Kizashi's wonderful strong points is it's view from the rear (wish I could say the same about my wife). In a review I once read it got slagged off because the actual exhaust pipes are smaller than the holes in the bodywork, how ridiculous !!KuroNekko wrote:They are growing in popularity and even preexisted the Kizashi (the Lexus LS is an example) but I've always thought the Kizashi's was unique because of the shape and size. However, it kind of always looked familiar to me and I couldn't grasp why until I read one review on the Kizashi that revealed its design origins. Can you guess what that was? Here's a clue:SamirD wrote: What I find interesting is that the rear exhaust finishers are almost identical to the Kizashi. I've actually seen these on a bunch of cars now, especially the newer models by GM (Impala, Regal).
Let's hope your wife does not visit this forum and read your posts. Otherwise, you will have a more intimate relationship with your Kizashi... as in a place to sleep in.paininthenuts wrote: Amongst many of the Kizashi's wonderful strong points is it's view from the rear (wish I could say the same about my wife). In a review I once read it got slagged off because the actual exhaust pipes are smaller than the holes in the bodywork, how ridiculous !!
I've also read the criticisms that the exhaust outlets aren't actually part of the exhaust pipe. However, I don't see why that's a bad thing. It makes removal of the bumper easier and also allows one to replace the exhaust system easier. If you get an aftermarket or custom exhaust, you'd not want the outlets to be connected to the actual pipe. The design also allows for larger diameter pipes.
Also, nearly all exhaust outlets are designed like this. This is because exhaust pipes move by themselves a little. Watch a car accelerate from the rear and you will see the exhaust pipe moving somewhat independently of the car. This is due to exhaust pressures. It's also why the rear exhaust pipes and mufflers have rubber hangers instead of being bolted directly to the chassis. They need the flexibility.
For a number of reasons, you don't want the actual exhaust pipe connected to the exhaust outlets/finishers.
- Contact:
i love the Kizashi but i wouldnt get it again
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
IG: N2OKizashi
I thought the ISF ones were real? At least they've looked real on every ISF I've seen.
Yup, the tips are not connected to the exhaust. Exotics did it too but I think the ISF was the first "normal" car to do it before it became common.SamirD wrote:I thought the ISF ones were real? At least they've looked real on every ISF I've seen.
I think the reception would've been better had Lexus opted for a more conservative style rather than the obnoxious vertical stack.
