Most likely if the filter isn't as restrictive as the stock filter. Which filter did you use?11zukizashi wrote:Hi, I also noticed that my engine sounds louder recently after i replaced the air filter at 30,000 miles. I did not use an oem filter i used a cheap one from rockauto. Maybe that is our problem?
Noisy, thrashing engine is getting old.
- 11zukizashi
Hi can someone who has an oem filter please measure the thickness of the rubber flange around the edge of the filter? I checked the airbox again last night and it is definitely closed but it seems like its not closed tight, like the rubber flange gasket is not thick enough and causing the cover of the airbox to have some movement and rattle.
If no one else responds before I'm home from work tonight, I'll help you out11zukizashi wrote:Hi can someone who has an oem filter please measure the thickness of the rubber flange around the edge of the filter? I checked the airbox again last night and it is definitely closed but it seems like its not closed tight, like the rubber flange gasket is not thick enough and causing the cover of the airbox to have some movement and rattle.
Is the OEM air filter clearly labeled as "Suzuki"? I don't recall seeing that on mine and it's also made in Korea. I'd think an OEM would be made in Japan.
I also ordered a replacement filter from Rockauto that should arrive very soon. I got a Wix filter. I can do a comparison and take photos, but I'm not sure if my current filter is OEM as I got the car used.
Sounds like mine was not OEM.bootymac wrote:My OEM filter says Tokyo Roki, made in Japan.
P.S., I also have a very strong feeling the OEM oil filter is made by Tokyo Roki. I was watching a video on "Suzuki OEM parts" on youtube and it showed clips of Suzuki engineers testing the OEM parts. The clip showing the oil filter reveals it labeled as Tokyo Roki. The video was for Suzuki motorcycle parts, but the filter featured looked like it was for a car, if I recall correctly.
There's more than one Suzuki p/n for oil filters. There's the made in Japan p/n and then there's the lower cost, China or Taiwan, filter number. Both are labeled and packaged as Suzuki. Purchased both at the dealer. I had posted the p/n's in an oil/filter thread a long time ago.
sold)
Measured my OEM filter and the gasket was 10mm thick11zukizashi wrote:Hi can someone who has an oem filter please measure the thickness of the rubber flange around the edge of the filter? I checked the airbox again last night and it is definitely closed but it seems like its not closed tight, like the rubber flange gasket is not thick enough and causing the cover of the airbox to have some movement and rattle.
I've noticed my engine has become very "clicky" sounding as of late when sitting at idle. Although it still sounds relatively the same as it did before when it comes to acceleration and cruising. I'm now over 42,000 miles.
Probably injector noise.
sold)
