Bluetooth Radio Question
If you're in the US, the only units that offer Bluetooth Audio Streaming are the Rockford Fosgate units without the navigation.
Personally, I think getting a Bluetooth FM transmitter is the better solution if you really only care for the audio streaming.
My 2013 SE has the "standard" stereo w/Bluetooth (non-Rockford, non-Nav), and I can stream audio over Bluetooth just fine. You just choose the 'BT' source on the radio.
If you also want to add Bluetooth calling you might need more things (steering wheel controls, microphone(s) ???). Not sure if the wiring for these exist by default or would need to be added.
Was it an extra option like satellite radio or maybe they included it for the latter model years?bdleonard wrote:My 2013 SE has the "standard" stereo w/Bluetooth (non-Rockford, non-Nav), and I can stream audio over Bluetooth just fine. You just choose the 'BT' source on the radio.
I thought about this too. The phone controls are on the steering wheel. The mic is next to the overhead light. You can check to see if the mic or wiring is there by removing the screw that holds the overhead apparatus in place (you can see the screw if you lower the sunglasses holder). After the screw is out, pull out the apparatus that contains the lights and check the wiring.bdleonard wrote: If you also want to add Bluetooth calling you might need more things (steering wheel controls, microphone(s) ???). Not sure if the wiring for these exist by default or would need to be added.
It appears the radio in my car is the part number 39101-57L21 (labeled 'PA57L2' on the face plate below the CD tray). I had not realized how deeply unusual it was, as it appears that it may have only come with the 2013 SE AWD models (in 2013 only the AWD SEs got Bluetooth, and only the FWD SEs got a power seat)
Here is a pulled unit that appears to be for sale (part number is listed wrong, but clearly states 'PA57L2' and 'BT' in the listing):
https://www.partsmarket.com/partnumber/ ... 0/24760523
Here is an old eBay listing with a few pictures (Click "see original listing"):
https://www.ebay.com/itm/2013-Suzuki-Ki ... 2064726798
I use a Bluetooth FM Transmitter in my 2010 S and it works great.KuroNekko wrote:If you're in the US, the only units that offer Bluetooth Audio Streaming are the Rockford Fosgate units without the navigation.
17 Sienna
17 Sienna
