Flashing lights on firewall?
sschriber
Doing some work under the hood at dusk and I noticed 3 (total) green and red flashing leds behind the battery near the firewall. Thing is, the car was turned off... Is this the on board computer/ECM? Why was it powered up? Hmm.
2010 Kizahi SE
2011 SX4 Crossover
Interesting...never noticed anything like that (wasn't looking for it either). Emissions evap tests run when the car is sitting there parked, 'off', doing nothing. I'm sure there are other things going on as well. Is there some sort of aftermarket gadget installed like an alarm or remote-start?
Nothing electronic now days is ever completely OFF. Unless you have a manually operated battery disconnect switch that is...
I've never noticed lights near the battery and agree with Ronzuki that your vehicle likely has a remote start or custom alarm system. Did you purchase the vehicle used recently? It may be the previous owner had something aftermarket installed.
sschriber
I did buy it used in 2012 with 33 k on it. Just passed 150k. Aside from part availability, this is a pretty solid car.
I'll take a closer look and get back.
2010 Kizahi SE
2011 SX4 Crossover
I've never seen any leds under the hood either. Definitely get back to us as it's a curious situation.
