Reposting from technical support:
I have the non-rf head-unit in my Kizashi (7 speakers stock, Panasonic?) without Bluetooth so I have to use a pendrive (Sandisk CruzerBlade). But I have noticed that a lot of songs are skipped by the HU. It just refuses to play those songs and skips to the next one. I read the manual and the format is inline with what is compatible with the HU.
Even though the manual states these as compatible, I still downgraded all my songs from 320kbps to 128kbps (some even to 112kbps) & then also reduced the sampling frequency from 44khz to 22.5khz (significantly reducing the quality). Even after doing this twice and reducing each song by more than 50% in size, the HU still skips them. I've even tried to compare the songs which work and which don't, and they are the exact same (bitrate, frequency, and more attributes). I've tried to diagnose it myself (changing pendrives, folders etc.) but I can't so I've come here asking for help. Does anyone know what to do? Thanks!
viewtopic.php?f=12&t=5415
USB player skips songs
- SAEED_KIZZY
did you try to clean USB connector with a contact cleaner or alcohol?
No, I don't think cleaning it would make any difference, and regardless it's very difficult to clean it. How should I?SAEED_KIZZY wrote: ↑Thu Mar 25, 2021 2:21 pm did you try to clean USB connector with a contact cleaner or alcohol?
- SAEED_KIZZY
as far as I know, when data is corrupted or misread by HU can cause this type of situation. it is not difficult just remove the cooldisk and spray cleaner in car USB connector and let it dry(when the car is OFF of course )
sometimes scan disk in PC can solve data corruption on cooldisk.
other than that there is not much to do I think
Where's the popcorn chomping emoji?
I know...not helpful. Couldn't resist though, sorry.
sold)
I'm sorry but what is a cooldisk? Do you mean the cover for the usb socket?SAEED_KIZZY wrote: ↑Thu Mar 25, 2021 5:35 pm as far as I know, when data is corrupted or misread by HU can cause this type of situation. it is not difficult just remove the cooldisk and spray cleaner in car USB connector and let it dry(when the car is OFF of course )
Also I can play all the songs on my pc from the usb, so it's the car that's not reading them properly. The songs can be played on my laptop & phone without any issues, so I don't think the songs are corrupted or anything.
- SAEED_KIZZY
cool disk = USB Flash memoryEndeavour1200 wrote: ↑Fri Mar 26, 2021 6:30 amI'm sorry but what is a cooldisk? Do you mean the cover for the usb socket?SAEED_KIZZY wrote: ↑Thu Mar 25, 2021 5:35 pm as far as I know, when data is corrupted or misread by HU can cause this type of situation. it is not difficult just remove the cooldisk and spray cleaner in car USB connector and let it dry(when the car is OFF of course )
