Where can I tap into a switched fuse
nytq
Anyone know where I can tap into a fuse that is switched and can handle a 5 amp draw? Preferrably in the engine compartment.
Northernstar
fuse box is right under the dash board. I tap into a 5 amp for my radar detector. fuse box diagram should be in the user manual.
nytq
Is the one you are using switched?
Northernstar
what do you mean by switched??
Circuit is only energized when key is on
Northernstar
ah~ic, then yup, it is switched. I removed the fuse that's for the the power outlet inside the armrest and then use an add-a-circuit.
nytq
great thanks guys
nytq
do you remember what fuse number that is? I don't see it listed in the manual clearly.
Northernstar
it's either fuse #7 or #8. kind of fogot which one it is. one is for the power outlet beside usb port, the other one is for the one inside armrest.
nytq
Thanks. I found ACC2 works perfect.
