murcod wrote:I had a look the other day - nothing.
However, the posted DRL procedure (that people have posted doesn't work) is in there.
I searched too and didn't find it.
I'm curious about that drl procedure as I know these procedures are pretty precise. It took me quite a few tries to get the TPMS relearn to work, and this is waaaaay more complicated. It wouldn't take much to mess it up.
It's a relatively easy one. Below's my abbreviated version.
IGN to "ON" and within 15 seconds do the following:
-Turn light switch ON/OFF to parkers 4 times
-Turn light switch ON/OFF to headlight 4 times
If it works you will hear a chime. Turn IGN off.
I'll try it on mine sometime. But by default I've got no DRL's - so I might be missing the DRL module?
murcod wrote:It's a relatively easy one. Below's my abbreviated version.
I assume every vehicle has the module but whether the DRLs are enabled or not depends on the market. It would make sense if there was an easy process to enable or disable them. The GV has a similar process
I just tried it and got nothing - no beeps. But Aussie models don't have DRL's to start with. So I might be missing that relay module thingy or have a different BCM.
Considering they've down specced the seat belt mechanism (compared to the USA) anything is possible!
I just tried it. Nope. Nothing. No beep at all. I tried it twice to make sure.
I had my doubts this was actually valid and this confirmed it. Not only that, others have failed to turn off DRLs this way too.
After all, it was from hearsay and no one actually could cite where in the service manual this was actually written.
Similarly, I also believe a live MPH display does not exist. Think about it. If it did, why wouldn't you be able to select it in the display set-up menu? If I can change Fahrenheit to Celsius and MPG to l/100 km in this menu, why wouldn't an option to display live speed be available if it existed?
bootymac wrote:Let us know if it works. I tried a similar method except it was on/off 5 times and it didn't work. I'll feel a bit cheeky if I was off by 1!
Five might be right? It says to do the step and then the next step says repeat the previous step four times?
Below is the exact wording from the manual:
1) Push engine switch to change the ignition mode to “ON”.
2) Perform Steps a) through f) described below within 15 seconds after Step 1).
a) Turn lighting switch to CLEARANCE position.
b) Turn lighting switch to OFF position.
c) Repeat Steps a) and b) 4 times.
d) Turn lighting switch to HEAD position.
e) Turn lighting switch to OFF position.
f) Repeat Steps d) and e) 4 times.
3) When Step 2) is completed, the mode changes automatically. Warning buzzer (in combination meter) sounds by the specified number for each mode as follows.
• Changed from “Non-operable” mode to “Operable” mode: Buzzer sounds twice.
• Changed from “Operable” mode to “Non-operable” mode: Buzzer sounds once.
4) After confirming buzzer, push engine switch to change the ignition mode to “OFF”.
The wording in the service manual under DRL's is "If Equipped" in the online service manual.
PS: Where did you get the "D-1 Headlight System Circuit Diagram" from in this thread http://www.kizashiclub.com/forum/viewto ... =12&t=3009 . The online service manual has the equivalent "D-1" diagram with no DRL circuitry displayed (unless I'm missing something?)
Edit: I worked it out. The online manual appears to be older/ missing info compared to the other pdf version floating around (from a certain Suzuki online info source.)
