Headlight Bulb Replacement
Is there really no way to repace the drivers side bulb with out dropping the bumper?? Seriously?
Thanks
John
2013 Kizashi Sport SLS
Pearl White
John
Pearl White
- Speed_Racer
Consider replacing both sides while you have it all apart. If one has failed, the other may be not that far behind.jcorcione wrote:Is there really no way to repace the drivers side bulb with out dropping the bumper?? Seriously?
Bx, how's the nitrous setup treating you? I remember you talking about it on Insta.
Sorry for the thread Hijack but I will also be removing the bumper to get repainted
I wish i had freakishly tiny handsnytq wrote:If you have freakishly tiny hands, maybe LOL. But yes, you have to drop the bumper. Not the best engineering design by Suzuki. I'm used to it now.
UPDATE:
hours later of which I will never get back the force was not strong with me. Not enough Midichlorians. Okay i went star wars geek there. Replaced the bulb and she still doesn't work. checked every fuse and nothing. AARRRGH. I feel like Charlie Brown. GOOD GRIEF. #SUZUKI #BADFORM
Can't believe this
Thanks
John
Pearl White
John
Pearl White
any one have any ideas?
Thanks
John
Pearl White
John
Pearl White
DesRado wrote:Did you plug the headlight housing back in for power. I forgot to do that once.
Yes, I did, as the other lights in the capsule work i.e. the marker and High Beams. Thank you for responding.
Thanks
John
Pearl White
John
Pearl White
Make sure the bulb is in good condition and the filament wasn't broken from shipping.
I'd also check the bulb harness for heat damage. Check inside the plastic harness and check the wires. The wires are rather thin so they may not withstand much heat before damage.
Also, make sure to check both fuse boxes just in case. I haven't examined the fuses in the Kizashi yet, but most cars have a fuse box in the cabin and also in the engine bay.
Did not check the cabin. I will do that this evening in the warmth of my garageKuroNekko wrote:Make sure the bulb is in good condition and the filament wasn't broken from shipping.
Thanks
John
Pearl White
John
Pearl White
