Audio System Upgrade Information
aranciata-oz wrote:
SAEED_KIZZY wrote:happy to help aranciata-oz any time :)
You're a legend Saeed .... all done now. It works like a treat! Thanks again!
Thanks aranciata-oz,I am glad it worked :)
TB16
Hi everyone, my kizashi's stock music system has thrown up a gremlin. The problem is that the display or the screen keeps flickering (comes and goes) with each second. Although everything else is working and the buttons are also functioning properly only the screen is malfunctioning. Any idea what it could be?
TB16 wrote: Sun Apr 11, 2021 7:33 am Hi everyone, my kizashi's stock music system has thrown up a gremlin. The problem is that the display or the screen keeps flickering (comes and goes) with each second. Although everything else is working and the buttons are also functioning properly only the screen is malfunctioning. Any idea what it could be?
did you try to disconnect the negative battery terminal?
TB16
No, I haven't done that. Will try that once and update here. Thanks
TB16
So disconnected the battery and back but still the flickering is there. Could it be a blown fuse or something like that? Or the display panel could be shot too.
TB16 wrote: Mon Apr 19, 2021 3:25 am So disconnected the battery and back but still the flickering is there. Could it be a blown fuse or something like that? Or the display panel could be shot too.
look like an internal problem to me.
but to be 100% sure check power and grounds for head unit.
TB16
I'm as it is thinking about changing the head unit. Any suggestions? Does the normal one and the higher variants RF head units different?
TB16 wrote: Mon Apr 19, 2021 7:03 am I'm as it is thinking about changing the head unit. Any suggestions? Does the normal one and the higher variants RF head units different?
Yes normal headunit and Rockford has a different connector you can not change them.
I think if you have non RF(normal) headunit you can also switch to android headunit or high-end aftermarket like Pioneer, JVC or just buy used OE headunit.
but in the case of RF headunit it is better to buy used OE Rrockford headunit only.
