If you're looking at buying double DIN I've noticed advertising recently for some units that interface with your smart phone. (You can run apps that are loaded on your phone from the head unit display.)
Sounds like a good idea to me as I use my phone for a GPS; with all the other applications that are available the limits are endless.
Double Din HU - The trials and tribulations
See the first post in this thread for the link.hocaspocas wrote:Minotrity.
Do you mind sharing a link where you purchased your unit. I am in the market for something similar...I was looking at ebay and there are some options like yours but not sure if they are the same.
(and it's Minority not Minotrity
For anyone interested the part number for the genuine Suzuki double DIN fascia is 73330-57L00-ZNF
A quick Google shows up this GARNISH TRIM 73330-57L00-ZNF $89.95 http://viewitem.eim.ebay.ru/20112013-SU ... en-US.html
It's also shown here as a genuine accessory- so should be available locally or from USA suppliers? http://www.suzukiauto.com.na/pdf/access ... ochure.pdf
http://en.gforceparts.com/parts/all/432 $73.07 on this page
This place does international delivery and prices it at 85 Euros http://eshop.original-teile.de/index.ph ... 3057L00ZNF
I have a genuine double bin facia. It came with my Kizashi S without radio but had the facia on.then I purchased a factory radio and remove the facia.
If anyone interested please PM and make an offer. we can make transaction on Paypal.
For anyone interested, the "factory" location for mounting the GPS antenna is under the dash centre speaker cover. You trim the ground plane down to fit in next to the speaker moulding and drop the antenna cable through the dash cutout. Or, if you're not interested in using the centre speaker, remove it and use the speaker screws to hold the ground plane and place the GPS antenna where the speaker was fitted.
There is also a microphone location within the front overhead light assembly, once again it's the factory location so should work well. You run the microphone cable through the roof lining and then down the front LHS windscreen A pillar, behind the glovebox and to the head unit.
- 11zukizashi
But if you remove the center speaker you should use aftermarket door speakers because center is wired in parallel with them using 2 voice coils. The resistance on the radio from the door speakers will be increased thus reducing output.
Make sure you know what you are talking about before you tell people to rip parts out of their car.
Yes, the centre speaker has twin voice coils from the left and right front channels; and is wired in parallel with the both the left and right front door speakers. The factory front door speakers (woofers) are 4 Ohms impedance- as are most aftermarket car speakers.11zukizashi wrote:But if you remove the center speaker you should use aftermarket door speakers because center is wired in parallel with them using 2 voice coils. The resistance on the radio from the door speakers will be increased thus reducing output.
Each to their own as far as removing the centre speaker. Remember this topic is about after market head units, not the factory system.
Any speaker's impedance will vary depending on the frequency of the signal being fed into it. It's purely an average value. So most head units will happily cope with load fluctuations.
The factory head unit (talking non RF, Panasonic manufactured head unit) is unable to supply enough power (voltage and current.) If you fit a different (decent) head unit to your vehicle you will quickly notice the difference. (Centre speaker fitted or not.)
(PS: Resistance is actually a DC term- speaker signals are not DC. The correct term is Impedance.)
- 11zukizashi
I am not an electrical engineer. Thank you for the correction. Seen a lot of misinformation on this forum its always good to double check. Cheers
I know this is an older topic, but you can find this on Parts.com (for cheaper than above)murcod wrote:For anyone interested the part number for the genuine Suzuki double DIN fascia is 73330-57L00-ZNF
Thanks for the tip - hopefully this link will work: http://www.parts.com/parts/index.cfm?ma ... h&siteid=2 US$50.69sal002 wrote:I know this is an older topic, but you can find this on Parts.com (for cheaper than above)murcod wrote:For anyone interested the part number for the genuine Suzuki double DIN fascia is 73330-57L00-ZNF
