Whiteline sway bar
11zukizashi
Has anyone tried or heard anything about these?
http://www.autoanything.com/suspension- ... 17778.aspx
claims to be 18mm and 3 point adjustable... cheaper than RRM but RRM is 19mm... still better than 16mm stock bar
Whiteline is (or was) an Australian based company and has a good reputation for their suspension products. The adjust-ability would be a bonus IMHO, in case you find it promotes too much oversteer.
Out of interest do you know if the stock fitted "D" bushes are rubber or polyurethane? Because a cheaper upgrade (if they're rubber) is to fit polyurethane bushes in their place. It effectively will provide a similar handling improvement and is significantly cheaper to do. (I've done it in the past on numerous vehicles.)
BTW, here's a direct link to their Kizashi products http://www.whiteline.com.au/do_segue4.p ... 10%2F09-ON
PRODUCT BENEFITS
This Whiteline 18mm 3 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll
