Exhaust
jadeng97
So I want to get some new mufflers. Has anyone replaced theirs? If so, what did you use. I can't seem to find anything that specifically says that it goes with the kizashi. Also, does anyone know the in and out pipe sizes for the mufflers? Maybe ill be able to find a muffler that would fit. I did see somewhere on here that someone used Borla 40351. But couldn't find any others. Thanks in advance.
gobster
If you are doing it to change the sound, you can just remove the mufflers at the flange quite easily to see if you like the sound. I had the flange removed and replaced by a short length of pipe so my exhaust now finishes just behind the rear axle.
