Kizashi Club
 #48938  by krell
 Fri Mar 01, 2019 3:30 pm
https://www.youtube.com/watch?v=a9DWGtX ... e=youtu.be
I just wanted to share the vid. Thought people might like it. While yes top name brands can be had for cheaper, if I can get "Good" oil on the cheap, why not. That's just extra money towards other things. I'm just an average middle - low class person with a family.
 #48939  by Woodie
 Sat Mar 02, 2019 11:56 am
Wow, $19 delivered for an oil that compares neck and neck with Mobile One? That's pretty sweet.
 #48941  by bdleonard
 Sat Mar 02, 2019 4:15 pm
It is made by Warren. They make and package a lot of the "house brand" oils for various stores (Walmart, Autozone, etc). It should be the same as their own MAG1 brand synthetic. You can go here and look up the dexos license number: https://www.gmdexos.com/brands/dexos1/index.html
All of the oils in that list with the same license number from dexos are the exact same oil.
EDIT: Updated Dexos link (current as of 01/26/2020)
 #51016  by SamirD
 Mon Jan 20, 2020 7:15 am
I hope they never have a problem with fakes or that value will down really quick when something goes wrong in the engine. :shock:
 #51391  by KuroNekko
 Tue Apr 07, 2020 7:14 am
Today, I purchased a box of the new Kirkland Signature Full Synthetic Motor Oil at Costco. I'm discussing it here given it's apparently the exact same stuff as the Amazon Basics Full Synthetic and Walmart's Super Tech Full Synthetic. They are all made by Warren and said to be very good for the value. Costco sells theirs for about $24.95 for a box of two 5 quart jugs. That's cheaper than a box of 6 quarts of Mobil 1 at Costco.
Historically in my Kizashi, I've used Pennzoil Platinum Full Syn 5W-30 from about 10,000 miles (first oil change after car purchase) to about 60,000 miles. I then switched to Mobil 1 5W-30 solely because I wanted to buy my motor oil at Costco. I basically ran Mobil 1 from 60,000 miles to my upcoming oil change that will be at 100,000 miles. While I think Mobil 1 is great, I've consistently experienced about 0.5 quarts of burn-off between oil change intervals which I did not see with Pennzoil Platinum. Sure, the engine has more miles, but M-1 burned .5 qts at 60K and still does at nearly 100K; it's been consistent. The engine also seemed smoother with Pennzoil Platinum in my experience. Hence, I'm eager to try something new for a significantly better deal. After reading and watching reviews and opinions on the Kirkland Signature oil, it seems like it's a safe bet. While M-1 might be technically better, I drive a Suzuki Kizashi, not a Corvette or a 911, and never been too thrilled about the half quart burn off I always saw with M-1. Lastly, going back to oil sold in 5 qt jugs will make used oil recycling a lot easier for me.
Anyone running the Warren Full Synthetic oils (Super Tech, Amazon Basics, Kirkland Signature) in their Kizashis for a while?
 #51395  by Tom Kizzie
 Tue Apr 07, 2020 8:34 am
Is it possible (maybe) that you drove a lot of shorter trips in your pennzoil time?
"when an engine is started the oil pressure needs to build up in order for it to fully protect the engine. Lots of cold starts means lots of times the oil isn't protecting the engine adding to the wear.
Also when the engine is cold the mixture is run rich to aid combustion. This extra fuel can result in bore wash due to it running down the bores washing the oil away. This fuel then enters the sump diluting the oil meaning the oil can't protect as it should. In extreme cases of lots of short runs and cold starts the oil level may rise due to the oil dilution with fuel. You can usually tell if this is a problem as the oil will smell of fuel. Prolonged bore wash will eventually lead to bore wear.
Excessive carbon build up can also occur due to the rich mixture on continuous cold engine use. The carbon will also contaminate the oil.
If you are doing a lot of short journeys with a cold engine you should change your oil more often due to all the above reasons"
