LEDs Inside and Out
~tc~ wrote:The trunk is a wedge type, not a festoon type. Those would work really well in the door as there are no reflectors. They will not work in the dome or map lights as they are aimed straight down.
Something like this would be fantastic, but I think they're too long
https://www.superbrightleds.com/moreinf ... 1701/4011/
The one I linked to comes with a W5W adapter so it should work in the trunk. I won't be using the diffuser though, as the board probably won't fit. Hopefully the light angle is wide enough to cover the entire trunk. Another possibility is wiring a LED strip to the W5W adapter
I also learned that the glovebox light is a T1.75 fitment... Not sure if a LED will have any benefits here. I want to change the license plate bulbs too, but they seem like a pain to access.
Edit: Here are the LEDs I ended up purchasing:
- Courtesy lights - 3W, 144lm
- License plate lights - 3W, 240lm
- Trunk light - 6W, 540lm
