So I had some spare time tonight and decided to see if I could start adding some grounding wires. I found some spare 8 gauge stranded copper wire leftover from past grounding kit projects. I picked up some ring terminals from Princess Auto (the Canadian Harbor Freight).
Here's the wiring. I would've preferred black but I have a lot of this stuff leftover.
- IMG_20140513_223840.jpg (218.56 KiB) Viewed 5481 times
I started with the throttle body as I thought it would be easiest and possibly the most effective, seeing how our cars are DBW. I connected one of the mounting points on the TB to the negative terminal on the battery. You have to move the intake hose back in order to get the 10mm TB bolt off. The 12mm grounding bolt on the negative terminal was torqued so tight that the entire terminal started warping when trying to loosen the bolt! It worked out but it was definitely more of a hassle than I expected.
Grouding:
- IMG_20140513_223957.jpg (358.19 KiB) Viewed 5481 times
Cover on:
- IMG_20140513_224135.jpg (347.66 KiB) Viewed 5481 times
There are a couple empty bolt holes on the engine block below the oil filler cap. I'll try adding a ground there next as it's close to the factory chassis grounding point. I'd like to improve the ground for the ignition coil wiring but I can't find it
