Factory paint run under the clearcoat???
murcod wrote:SamirD - go check your bonnet in the sunlight like in the pictures above. I'd be most surprised if you haven't got similar dents- they're very hard to spot.
I think you'll find in the owner's manual it will tell you to drop it. You even need to be careful closing the boot (trunk) lid these days, body panel metal just isn't as thick as it used to be back 20-30yrs ago!
Edit: from the owner's manual
To close the engine hood:
1) Lift the hood up slightly and remove the
prop rod from the hole (5). Put the prop
rod back to the holding clip (4).
2) Lower the hood close to the bumper,
then let it drop down. Make sure the
hood is securely latched after closing.
I'll check for any dents, but since I'm so particular about things like creases in the metal (I even get irked when the reflections are even across body panels or on marble tile floors), I don't think we have any. If the Kizashi hood wasn't so easy to shut by just pressing down on it, I definitely wouldn't be doing it.
Interesting how they say to drop it in the owners manual.
bootymac wrote:Wow, learn something new everyday
Cool, isn't it? :D
DWenz
Ok. I have looked to the point of obesessing. There is NO dent.
I did however have an issue last year where the rubber bumpers were allowing too much play in the hood. Dealer adjusted (to no improvement) and the service guy was pushing on the hood some. THAT may be when it happened. They will never admit it! IF that did it this car is pathetic. And as impressed as I am in some ways I am so learning this really IS a Suzuki afterall. Have to cut some corners to pay for the tech and styling I guess...
2013 SLS AWD
DWenz wrote:Ok. I have looked to the point of obesessing. There is NO dent.
You just contradicted yourself. You claim it's not a dent yet your best theory on how it was caused could only be a dent. Keep in mind that you can't always feel every imperfection nor see it. Some you see, some you feel. It's probably a dent you just can't feel. On the contrary, clay bars remove contaminants you can't see well, but can feel.
Also, not sure what you mean about Suzuki. They are cheap cars, but are pretty good for the value. I really don't think rivals are significantly better. I've owned or worked on cars from just about every Japanese brand and haven't seen cars that were made significantly better than a real Made in Japan Suzuki. They are all on par with each other and the biggest difference I see is just brand reputation/perception among consumers.
All cars have their flaws and redeeming factor. Generally speaking, Japanese cars have thinner and weaker body panels than domestics and Euro cars so they dent/damage much more easily. Their positives are commonly high reliability, value, and longevity.
Euro cars have awful electronics and dismal reliability with high repair costs. Their positives are high attention to detail, driving dynamics, and performance.
Domestics are often overall low quality and are built by apathetic workers. However, they offer among the best values in terms of price/performance ratio and are among the most affordable cars. Every kind of car has its positives and negatives.
If the little dent bothers you so much, I again strongly suggest you talk to a paintless dent removal pro. They can get it out if it's a dent, regardless of whether it can be felt or not. That's because of the process they use of massaging out the imperfection from both sides until it's perfectly level and invisible.
That would have done it.
Pathetic? No, just normal for any modern vehicle. You should never push any bonnet/ hood shut.
PS: Try doing a search on Google for "dent hood shut".
Speed_Racer
Have fun with any other new car. Thin bodypanels are the new norm thanks to increasingly strict corporate MPG standards, pedestrian impact crash standards (why do you think the hood is shaped like it is), etc.
The days of durable, thick sheetmetal is long gone. All we can hope for are aluminum panels becoming more cost effective.
Speed_Racer wrote:Have fun with any other new car. Thin bodypanels are the new norm thanks to increasingly strict corporate MPG standards, pedestrian impact crash standards (why do you think the hood is shaped like it is), etc.
I think the time has come given America's best selling vehicle will have an aluminum alloy body for MY 2015.
http://www.ford.com/trucks/f150/2015/
KuroNekko wrote:I think the time has come given America's best selling vehicle will have an aluminum alloy body for MY 2015.
At least you can recycle it easily and say it 'crumpled like a coke can'. :lol:
