Fritz2 wrote:Regarding the tire gel, I don't use tire shine anymore as many people have told me it degrades the rubber and leads to premature sidewall cracking. I just wash and leave the standard dry look, tire shine looks so good though!
I think it depends on the kind of tire shine product you use. Some are good for the tire as they contain protectants and rubber conditioners that help prevent tire rot. Others that have solvents and silicone are said to promote tire rot.
Personally, I think it's somewhat irrelevant. Quite frankly, I drive enough to the point where the tire's treads will wear out before sidewall cracking occurs. By the time I noticed sidewall cracking on the OE Dunlops, the tread was also low and the tires were worn unevenly due to the Kizashi's factory alignment issue. Basically, the tires were done by the time the sidewall cracking was an issue. I also think higher quality tires will be more resistant to sidewall cracking from their rubber formulation.
It seems that sidewall cracking is most prevalent on old neglected tires, indicating that age and neglect, not products used, has the most to do with it.
kconklin33
I did not do much with my car, but I actually put new wheels on my girlfriend's 2015 Murano, washed it and took some pictures! Here is the look. The new Murano is actually a freaking good looking SUV. Hers is the artic blue metallic color.
PS I am kind of jealous...those wheels (18) would have looked great on my Kizashi.
G13b
kconklin33 wrote:
Cut spring or adjustable coil?
kconklin33
G13b wrote:
Adjustable coilovers.
G13b
kconklin33 wrote:
I'm intrigue what brand is the coil over and how much was it? +25 offset is too far off any scraping noise on hard cornering?
kconklin33
They were built in house with help of another member on here. A lot of time and planning went into the design. Et25 sets me just about flush maybe a little poke but I'm also 9.5 & 11.5 wide. But no rub or scraping
DiggerDerrik
Changed the engine oil and filter along with the transmission filter and about 60% of the fluid. Will turn over 100k this week. Best car I've ever owned.
2010 Kizashi GTS FWD
Tanshanomi
I published an article on the Hooniverse to commemorate our first anniversary. Even gave KizashiClub a plug.
http://hooniverse.com/2016/05/16/the-ki ... eymooning/
2011 GTS Sport 6-Speed • 2013 Can-Am Spyder RS-S • 2002 Ford F150 SuperCrew • 1977 Bultaco custom roadster • 1973 Honda CL125S
Nice article! I have a 2012 just like yours minus the sunroof.
Oil change and tire rotation. Replaced rear brake pads... they were awfully worn.
