golftango
golftango wrote:
I had popped it off earlier and there is a photo sensor there. I read it had to do with the HVAC. Maybe the auto lamp function has to be activated or run by the BCM or is a separate photo sensor.
Are you sure that the harness connects to an actual sensor rather than a dummy? I was surprised to see the wiring but it doesn't make sense for a company to install a sensor on cars not equipped to use them. The dome on my sensor also looks like solid plastic rather than a tinted plastic. I'd be pleased to be wrong so your mod can work out better.
Decided to look into this some more. It is a light sensor, but only for HVAC operation. The light sensor for the auto lights is in the windscreen. Found this out by looking in my user manual! Lol.
Here's the sensor for the HVAC which is the button on the dash:
Fun fact, when cross referencing this part number it was used in Rovers, Mazda, etc.
I'm going to see if the wiring resides in the headliner as I have a spare photosensor lying around.
2019 Kia Optima EX Premium
Instagram: golftango
Interesting. How exactly does the photosensor work with the HVAC? Is it for the auto climate control in that it not only detects cabin temperature but the amount of light too?
golftango
KuroNekko wrote:Interesting. How exactly does the photosensor work with the HVAC? Is it for the auto climate control in that it not only detects cabin temperature but the amount of light too?
My guess, to detect day/night conditions to control blower motor and increase/decrease temp intensity.
And sunny/cloudy. There's some predictive logic in the auto temperature control. If it knows the sun is beating down like a demon it runs the A/C a little bit longer than it would if it's a gloomy day, rather than just slamming it on/off when it gets to the target temperature.
DiggerDerrik
Ordered the third set of tires the car will wear (I'm including the tires it came with as the first). Found Firestone Fuzion Touring tires for $350 shipped and no tax. Figure mounting, balancing and tpms rebuild will be another $100. So a pretty good deal. I found them on Simpletire . Com. Not all their tires come with free shipping but I found them to be a lot cheaper then tire rack. Car has 112,000 miles now. Current tire is Goodyear Eagles I put on when the car had 51,000 miles. Tread is down to 3/32nds.
2010 Kizashi GTS FWD
I am honestly not trying to be a dick, but you may find that hard to believe when I say I wouldn't put those tires on my lawn mower. Tire Rack lists 77 different tires for a 2010 Kizashi GTS, and that is the absolute #1 bottom tire out of the 77.
I'm on staycation this week and I'm going to try to get some things done on the Kizashi. Needs an oil change and I think I'm going to change the transmission lube and bleed the brakes and clutch. Also need to take the wiper motor out and figure out why it won't park automatically. That used to be a contact disk and wiper inside the wiper gearbox back in the day, but who knows how they do it now? Figured I'd pop it open and give it a whirl before I splash out the big bucks it's probably going to cost for a replacement.
golftango
When I bought my Kizashi, the OE Dunlops were almost bald @ 16K. I drove across the street to a WalMart and had some Douglas Performance GT-Hs installed for a mere $72 a tire. They are a made in the USA, Goodyear tire. Now at 39K, they still have tons of tread left. Additionally they are a quiet, smooth, grippy all season tire. I highly recommend these as a budget alternative to any off-brand or Chinese tire.
Looks like Douglas has a newer, better wearing Performance tire now.
DiggerDerrik
Woodie wrote:I am honestly not trying to be a dick, but you may find that hard to believe when I say I wouldn't put those tires on my lawn mower. Tire Rack lists 77 different tires for a 2010 Kizashi GTS, and that is the absolute #1 bottom tire out of the 77.
I did a little fact checking after you brought this up and you are incorrect. The Fuzion lands in the middle of the pack as far as reviews go. They are even rated higher then the Goodyear Eagle tires they will be replacing after 60,000 miles. Are the Goodyears worthy of your lawnmower? This is from the Tire Rack website.
Actually that was a quite dismissive statement, I should have been more clear in that for what I value when shopping for tires they're not great. When they came up the page was sorted according to price and they were the cheapest of 77. That's not a good sign, but it's entirely possible that they're just overstocked on them and the price is artificially low right now. I saw that and the 400 UTQG rating and called them crap. I consider 400 to be the cutoff point for tires, anything above that I will not consider. My main concerns are wet and dry traction, I ignore any tire which brags about how long it lasts because that usually means it is too hard to give decent wet traction and braking.
I need to reminded from time to time that I'm not the only person in the world and that sometimes others have different, yet perfectly valid opinions. Sorry.
Woodie wrote:Actually that was a quite dismissive statement, I should have been more clear in that for what I value when shopping for tires they're not great. When they came up the page was sorted according to price and they were the cheapest of 77. That's not a good sign, but it's entirely possible that they're just overstocked on them and the price is artificially low right now. I saw that and the 400 UTQG rating and called them crap. I consider 400 to be the cutoff point for tires, anything above that I will not consider. My main concerns are wet and dry traction, I ignore any tire which brags about how long it lasts because that usually means it is too hard to give decent wet traction and braking.
Yeah, keep in mind that these are "Grand Touring" tires and not Ultra High Performance or Max Performance Tires. I'm no expert on tires, but my research tells me that GT tires are intended for a prolonged service life for general use. They are basically intended to be quiet, comfortable, and last a longer duration for normal driving. Performance isn't a priority with GT tires.
UHP tires sway on the side of performance as the name implies but generally compromise on tire tread life by using softer compounds for better traction. Even then, UHP is still a compromise given nearly all All Season tires don't go beyond this performance rating. The stickiest tires for the best performance are Max Performance and the rare "Extreme Performance" rated tires. However, these are nearly exclusively Summer tires and aren't design to grip snow, ice, or even work ideally on cold tarmac.
So in the end, it's about where you drive and what you want out of your tires. Most people are fine with GT tires if they use their car for transportation more than pleasure. UHP offers more grip for performance without compromising too much when things get wintery (assuming they are All Season). Max and Extreme are for dry summer use or track use and need to be swapped out for winter tires for those in regions that get snow in the winter. I hear they are dangerously slick on snow.
Once I move to So Cal and the time comes for new tires, I think I'll get Summer tires for the first time ever, especially since I will no longer live on a mountain there. As for here in the Mid-Atlantic, I've been very pleased with my Michelin Pilot Sport A/S 3 tires I've had for over 25,000 miles.
