Nice lineup!
How did the Kizashi compare to the others?
Not too bad actually! Had nothing on the Seat though, that thing has about 270bhp in it!SamirD wrote:Nice lineup!
Kizashi probably handled the corners the best & had the legs on the Audi & Ford, with it being Auto though the initial acceleration was/is poor.
Changed headlight bulb...never seen this happen before! Then forgot to put cap/cover back on back of headlight housing. Left it lying in the engine compartment somewhere
. It fell out and is long gone now.
- Kizashi bulb.jpg (196.2 KiB) Viewed 10860 times
Michelin Crossclimate 2
Power Stop Rotors and Pads
Decided to shave some weight off the Kizashi! But seriously, what purpose do these really serve anyways? A little snow tears them right up!
- Kizahsi parts 2.jpg (255.47 KiB) Viewed 10860 times
- kizashi parts 1.jpg (299.9 KiB) Viewed 10860 times
That bulb looks like what happens when someone touches it with their bare fingers. The oil from the skin stays on the glass and alters the surface temperature when hot, creating a vulnerability in the integrity of the glass. This is why it's recommended to wear rubber gloves when handling new halogen bulbs.n8dogg wrote:Changed headlight bulb...never seen this happen before! Then forgot to put cap/cover back on back of headlight housing. Left it lying in the engine compartment somewhere. It fell out and is long gone now.
Those are to reduce aerodynamic drag under the vehicle thereby improving fuel economy and reducing road noise. They also deflect dirt, snow, and salt from getting up into the chassis so they may help to prevent corrosion.n8dogg wrote:Decided to shave some weight off the Kizashi! But seriously, what purpose do these really serve anyways? A little snow tears them right up!
Maybe dissemble it every year..clean stuff up and assemble again? @the same time with checkup&maintenance
kizashi 6mt black
Those plastic skid plates are put there to collect dirt. Which then falls into your eyes while removing them.n8dogg wrote:Decided to shave some weight off the Kizashi! But seriously, what purpose do these really serve anyways? A little snow tears them right up!
I also ALWAYS forget to put those headlight seal things back on. I usually notice them laying on my battery just after I finish putting everything back together.
2010 Kizashi GTS FWD
Drive to work and back home and managed to get 8.3l/100km. Then i parked inside and cleaned the wheelarches and underbody from all snow ice dirt.
kizashi 6mt black
