CVT Fluid Drain and Fill w/ Filters Replacement
hillboy73
I'll just do it as your post and Old Tech recommended :lol: thank you for all the input. I'll let you know how the Triax fluid performs.
hillboy73
Is bubbles in the fluid normal when hot, caused by too high if a level, or too low of a level? Just trying to get the level right
I tried to find what model yr you have. Id like to confirm you have the correct filter depth. 12 and 13s came with a deep pan and the correct filter (pick up screen) is unobtainable aftermarket. They will usually hand you the short 10-11 screen. Using a shot filter with a deep can can cause damage. Just cleaning the original is recommended . If you must replace it , an Altima screen has the correct depth. Maybe you are talking of the cooler filter. Bubbles can be normal if it fluid has just been added. Check it again after a day. Level fully warmed up should be 1/8 higher than hot full line on the more common stick with the drilled holes or right on the line on the revised stick with the triangle cuts.
hillboy73
Sorry I haven't added my vehicle info yet. It's a 2011 SLS Sport AWD. It has the drilled stick. I used the same filters as posted in this thread I believe. I did just add a little fluid (maybe a 1/5 quart) as it was reading around an 1/8" below the top hole. I drove probably 20 miles mostly all highway and when I checked it it was bubbly and like a half inch if not a little more over the hole. Is there not a way to check these at an ambient temperature not running? Seems like you can check the stick 3 times in a row running and get a different reading.
n8dogg
old tech wrote: Id like to confirm you have the correct filter depth. 12 and 13s came with a deep pan and the correct filter (pick up screen) is unobtainable aftermarket.
I somehow missed that little nugget of wisdom when I serviced my '12 Kizashi 25k miles ago! At 95k I did my first CVT service, including changing both filters. Everything seems fine so far. I'm planning of doing another full drain and refill soon...should I be looking for a different filter since I plan on dropping the pan?
Michelin Crossclimate 2
Power Stop Rotors and Pads
Quimicax
If Everything Is Working Correctly Use The Same Model,
Recently Change The Cvt Fluid With Both Filters, I Am Using Motul Cvt Is Synthetic Base And Color Is Blue Like New Nissan NS3 CVT Fluid, Previously Used Valvoline CVT, The Trans Pan Magnets Looking Very Clean I Liked That
Before
It Looks Shiny But It's From The Cell Flash
After
2013 Model With Original Transmission And 128,000 Miles (204,800km)
Kizashi GTS 2013 AWD
Ford Explorer Sport 2013
350Rwhp
Nissan Xtrail 2017
hillboy73
Just thought I'd let everyone know that the Triax fluid has seemed to work fine so far after about 500 miles which isn't really much, but in contrast to what I read somewhere the fluid is red, not a clearish yellow color.
Quimicax
hillboy73 wrote:Just thought I'd let everyone know that the Triax fluid has seemed to work fine so far after about 500 miles which isn't really much, but in contrast to what I read somewhere the fluid is red, not a clearish yellow color.
Original Suzuki Fluid Is Green Color
Very Few Aftermarket Fluid Are Red, To Avoid Confusion Between A Conventional ATF Fluid
Many Cvt Fluid Brands Are Green And Yellowish
And The Most Recent Depending Are Blue Color
Like New Nissan NS3 / DIA QUEEN J4 And Motul CVFT
350Rwhp
Nissan Xtrail 2017
hillboy73
I had just posted previously that it was supposed to be a clearish yellow according to something I read when researching and I just wanted to clarify that was not the case
In the above posted pictures, the before pic is the 12-13 yr deep pan . The after pic is the 10-11 short pan . See the different magnet location. They each have their own filter. The short filter in the deep pan is not a good thing. It could lead to fluid starvation given a low level and just the right tilt. Unfortunately ,the earlier pan filter typically, is all the part stores have listed for all Kizashis. The longer reach 12-13 filter in the 10-11 pan is not possible. On the topic of fluid color. its possible for manufacturers to make it any color they wish. Castrol makes a very good cvt fluid thats red. I wont use it for the simple fact of I may be accused of putting the wrong fluid into someones transmission which led to a failure.
