KuroNekko wrote:I think as long as the bushings aren't blasted with water, they should hold the grease for a decent amount of time. Of course, the type of grease would matter quite a bit and I agree that the original grease was probably less than ideal. However, my bushings didn't start making noise until I rinsed off the underbody with a hose. My guess is that water got into the bushings that way given the grease was mostly gone by that point.
I'm hoping the Sil-Glyde will last a while given its water and heat resistance but it may also be that these polyurethane bushings simply need a re-greasing every 1 to 2 years to maintain optimal lubrication. Time will tell.
It's all in the grease! Poly sway bar bushings don't need grease to function; the grease is just there to eliminate squeaking. It's more important to pick something that is durable, such as a silica (Super Lube, Silglyde), polyurea or calcium/aluminum (marine) based grease. I'm not sure about Astroglide or KY Jelly though
Does it rain a lot in your area? It rains quite a bit here so that probably washed away my original grease.
Yeah, it rains decently here, unlike California. The summers often have their thunderstorms.
If desperate enough, maybe one can try KY Jelly? Me love you long time, polyurethane bushings!
WESHOOT2 wrote:Today (actually, around 2:45 AM; yes I was out driving around) I drove my 2011 Kizashi past 159,000 miles.
It was cool; I looked down and noticed I was 159,000 exactly.
Now I have more :mrgreen:
That's it. Please drive it past 200,000 miles.
Mebbe.
Mebbe not.
It's (always) about the 'drive'.
Speed_Racer
Who needs an SUV anyways? From this weekend.
Sweet! Where is that?
Speed_Racer
bootymac wrote:Sweet! Where is that?
Just outside of Moab, UT!
I did this a few days ago!
That looks pretty good. What did you use? Will you so the same to the chrome bits?
golftango
so now it looks like a Jetta... ;) 8-)
2019 Kia Optima EX Premium
Instagram: golftango
