NJKizashi wrote:Hey Guys,
For the life of me I cant get the Clip that holds in the H7 Bulb on the "Left" side lamp out.
I know it's just a matter of getting your Hand in there, I feel the clip, I did exactly what the Owners Manual says....But that Friggin Clip does not want to let loose of the Bulb... !!!
Any Suggestions ????
It's not the easiest task, unfortunately, but it can be done (I've done it three times already, and struggled quite a bit each time). I'd suggest you practice on the right side lamp to get a feeling of how the clip releases (you'd probably want to replace both bulbs at the same time anyway) and, once you have a clear mental image of what you have to do, place a couple of thick band aids on your right hand middle finger and try again. You'd have to press really hard before you can move the clip laterally, and it helps if your finger does not start to hurt. Place the index finger on top of the middle on for added force, unless you have very strong fingers.
What I found I was doing wrong was that every time I tried to move the clip laterally before pushing it all the way back and out of the hook. This is where having a bit of practice with the other, easier, lamp will help.
Good luck.
P.S. Taking the bumper off is another option, of course, you can search the forum for instructions.
