wheel center caps
PittsburghJoe
Hi Guys,
I just lost a center cap off a wheel on my 2012 sport sls. Do you guys know the exact size of them? There are a few different sizes on ebay so I don't know which one to go with.
thanks,
Joe
vapor2
60.1 mm is the diameter of the center bore. I don't know if the cap will be different size. Hope this help
PittsburghJoe
vapor2 wrote:60.1 mm is the diameter of the center bore. I don't know if the cap will be different size. Hope this help
Thanks vapor. I'm not sure if it helps or not. It sure doesn't hurt though. Do you know if its the same size as any other suzuki center caps? I can get one for the dealer for $19 but I still think that's a lot for a 2 oz. chunk of plastic.
Thanks,
Joe
vapor2
I don't know if other Suzuki center cap will fit. If you find out, let us know. thanks
PittsburghJoe
Even with the power of google I couldn't get an answer as to which center caps fit what so I plunked down the $17 for a new one. Oh well.
jono6406
mines was 2-1/16 inch which is what the new center cap measured.
