No Control of Passenger Window
KZChi
Hey guys, I just changed the Non RF headunit on my SE and added a Pioneer AppRadio double din with the ASWC-1 wheel remote control. Well after I finished the install, I noticed that I can't control the passenger window from the driver's side, no up or down. But if I reach over to the passenger door I can still control it. I checked several fuses in all 3 fuse boxes and nothing was burned out. These are the fuses I checked:
Engine compartment box
#8 power window/power seat
Under driver side box
#1 power window
#7 accessory 2 (I checked these because I remeber there being an accessory wire on the radio harness)
#8 accessory
#23 front power window (left)
Under passenger box
#3 front power window (right)
Anyone have any ideas on what else I could check? Could it have been anything to do with the radio harness?
BxKizashiS
the radio has nothing to do wit the power windows, even if u have the all the radio wires disconnected u should still be able to put the window up or down.. did u try puttin back your old radio to be 100% sure? Seems like u checked all the fuses so maybe something is disconnected. A harness maybe, did u cap off all unused wire wit a crimp cap or butt connector?
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
KZChi
Hey BxKizashiS, i did go back and installed the factory radio again but no luck. Several people have told me that the radio should have nothing to do with the power windows. Its just so strange to me that it stopped working after my install, maybe just a coincidence. I did cap every unused cable. I'be been a little lazy and scared to check behind the door and check the switch, so i might take it in to see if the dealer can check under the warranty, i just hope they don't give me some nonsence since i switched the radio myself.
