Disengage e-brake control
MattC512
I'm looking for some help disengaging the e-brake control on the stock Kenwood navi so DVDs can be played while the car is in motion. Any help is appreciated.
jono6406
All you have to do is ground the light green wire in the back of the headunit and you will be able to watch DVD's while in motion, you wil be able to use the telephone feature while in motion also.It's very easy just remove the lower panel by slightly opening the door then reach up under it and give it a slight tug then when it's out you will see one screw on each side of the headunit. Unscrew them and the headunit will slide straight out, the send the green wire to ground and your done other that putting everything back together. Reminder... just make sure you don't let those screws fall down under there.
MattC512
Thank you for your response.
Is this the green wire?
MattC512
or 1 of these?
jono6406
Not sure by looking at your pic's but the green wire should go nowhere. You can ground it to any body part or tie it into the black ground wire.Your green wire should say park brake ( tag) somewhere on it.
