Thanks for the feedback everyone.
I have just uploaded another release of the main guide -
Suzuki Kizashi Audio and Navigation Systems.pdf, with additional information on the pinouts and access to the RF audio amplifier and the circuit diagram of the steering wheel controls.
If there is any information any of you personally need, please request it in this thread and I'll do my best to find it for you.
murcod wrote:Welcome Elyse.
I did something similar and fitted the 2010 model Kenwood Navigation Unit (I got my hands on the genuine factory upgrade kit to suit the XLS... ironically) to my 2011 Touring. That included all the necessary wiring loom interfaces, microphone, dash parts etc. The wiring loom adapter wasn't "plug and play" due to the wiring differences between the 2010 Prestige and 2011 Touring (ie. Rockford Fosgate head unit with external amplifier vs mine with normal head unit and internal amplification.)
I didn't have to contend with adding the steering wheel controls - I just answer calls by using the head unit touch screen.
You'll have a lot of wiring ahead of you. Good luck.
Thank you! Glad your install turned out OK. Fortunately, my XLS has almost everything I need already in it, even if it's unused for the Australian market. Up until the end of the 2012, there were only two audio system variants here, and I've only seen one or two with the Kenwood navigation system fitted.
For the 2013 model year, the Rockford Fosgate system was fitted to the the two lower models (replacing the previous non-amplified system on the base model) and the highest model comes with the Garmin navigation headunit but no external amplifier.
The extra wiring won't actually be that bad. I have passthrough harnesses to suit the amplified and non-amplified systems already, so I can modify them to suit my install. My biggest hurdle is sourcing the right connectors for the rear view camera and navigation control inputs... I haven't yet been able to find the originals at RS Components or Farnell, and I expect they'll cost a small fortune for single quantites.
Worse comes to worse, I'll just open up the Garmin unit and piggyback some generic connectors on to the existing ones, so I can retain plug and play ability. There's only four wires plus the reversing camera video cable to add... Everything else I'll need is already at the connectors behind the original headunit.
I can say empirically that the Rockford Fosgate headunits output line level signals only - I removed mine and popped the lid, and they don't have any form of internal amplification.
I intend on using a Scosche 4 channel adjustable speaker to line level converter between the new headunit and the RF amplifier. They use a transformer and loading resistors on each channel and are a considerable step up in quality from the simple voltage divider line level converters that Suzuki used to fit the Kenwood navigation systems (and the one used on the Scosche SI06B harness).
If I lose any sound quality, then the next step is to build some small buffer and line driver PCBs and add real line outputs to the Garmin unit.
The Kizashi's audio system is pretty straightforward compared to my last car - A Holden VE Commodore (known in the US as the Pontiac G8). Myself and a group of other enthusiasts actually had to take software dumps from the EEPROMs inside the head units, and work out how to modify them in order to change the VIN lockout and allow headunit swaps and upgrades between cars. The Kizashi stereos aren't even on the CAN bus, so they're basically just a nicer fitting aftermarket unit from an electronic perspective.
