97 ron bp
Tommybhoy25
Hi guys Ive tried to see If I would get better mpg with using 97ron bp fuel. I put £30 in it that was 95 ron bp fuel last week then decided to top it up with 97 ron bp fuel in it made no difference. so I then put in £30 97 ron in it when it was low. The car felt a bit sluggish when I slipped it into manual. So as i thought 97 ron was to strong for the car am I rite in thinking It was to strong or Im I experience a problem with the car baring in mind its only done 4k. What do you guys think is it set up for 95 or 97 ron
paininthenuts
Who's Ron ?
95 RON = 91 octane
97 RON = ~92-93 octane
The Kizashi can run on 87 octane (91 RON) so higher octane fuel shouldn't be a problem
BxKizashiS
Gas too expensive to go more than 87 octane lol.. wish i could go higher, like 94 sunoco
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
Compression ratio in the Kiz is pretty high, watch for knock/ping when running the lower octane stuff.
Higher octane gas has less power in it than regular, it burns slower and cooler, there's no such thing as "too strong for the car". Some have reported better gas mileage on higher octane, I tried it and saw no difference whatsoever. The PCM controls the engine according to gas grade, you should never hear any knock, the only way to tell any difference would be very accurate power and mileage measurements.
Run mine on the lowest octane available, 87 I think, runs great and gets 30 mpg.
Most lower grades in the US have 10% ethanol in it, which will decrease mileage and may not be good for the life of the egr systems. Premium fuel has better additives in it that keep everything cleaner along with a higher octane rating.
But unless the car is self-tuning enough to take advantage of the higher octane, it won't make a difference. To me, anything without ethanol is better. A lot of my older cars can tell a big difference.
Tommybhoy25
Hi guys thanks for all your input. I just thought because I had only did this change and I noticed the car in manual had changed. I am now going to see about the LPG conversion at a cost of £1400
Interesting that there's an LPG conversion available. Is it that much cheaper than normal gas?
Tommybhoy25
Samir Im from Glasgow and the price are. £1.28 for petrol and £0.66 for gas. The conversion costs £1400 I think its a no brainer to be honest
