The Kizashi DIY/FAQ Index
Manuals:
- Online Manual: https://avnet.ws/kizashi/Xml/SAW10A/
- 2010 Owner's Manual: see attachments
- 2010-2011 Service Repair Manual: http://www.kizashiclub.com/forum/viewto ... 008#p21008
- 2011 Service Manual: https://www.dropbox.com/sh/7sa4wbee9zwi ... 4wMHa?dl=0
- Repair/workshop manual: http://www.kizashiclub.com/forum/viewtopic.php?t=3457
Fluid Specs: http://www.kizashiclub.com/forum/viewto ... =32&t=2777
- Engine oil: API 5w-30; 4.5L (4.8 qts)
- Engine coolant: Suzuki Super Long Life; 6.6L (6.9 qts)
- CVT fluid: Suzuki CVT Fluid Green -1 or Shell Green 1V; 8.34L (8.8 qts)
- MT fluid: API 75w-80 GL4 gear oil; 2.5L (2.6 qts)
- Transfer gear box (AWD): API 80w-90 GL5 hypoid gear oil; 0.9L (0.95 qts)
- Rear differential (AWD): API 80w-90 GL5 hypoid gear oil; 0.9L (0.95 qts)
- Air conditioning refridgerant: HFC R134A; 530g (1.16 lbs)
- Fuel: 63L (16.6 US gal)
Maintenance Parts (for cross referencing): http://www.kizashiclub.com/forum/viewto ... =28&t=2383
- Oil filter: OE 16510-61A31, Mobil 1 M1-103, Bosch 3325, Purolator 14477, etc
- Air filter: OE 13780-57L00, NAPA FIL9008, Wix 49008, Purolator A36123, Fram CA10998, EcoGard XA6123 (reuse OE gasket), K&N 33-2441, etc
- Spark plugs: NGK 5468 SILFR6A11
- Cabin filter: OE 95861-57L00, Wix 24120, Fram CF10546, etc
- Wiper blades: 24" and 20"
- Front brake pads: Akebono ACT1338, Akebono ASP1338, StopTech 309.13380, etc
- Rear brake pads: Akebono ACT537, Akebono ASP537, StopTech 309.05370, etc
- Shock absorbers: KYB Excel-G 349141 (rear), 339265 (FR), 339266 (FL)
- Key fob remote battery: CR2032
DIY Maintenance Guides:
- Oil change: http://www.kizashiclub.com/forum/viewto ... =32&t=1483
- Air filter: http://www.kizashiclub.com/forum/viewto ... =32&t=1555
- Spark plugs: http://www.kizashiclub.com/forum/viewto ... =32&t=1578
- Cabin filter: http://www.kizashiclub.com/forum/viewto ... =32&t=1556
- CVT fluid and filters: http://www.kizashiclub.com/forum/viewto ... 621#p39621
- Manual transmission fluid: http://www.kizashiclub.com/forum/viewto ... =32&t=2623
- Tire rotation: http://www.kizashiclub.com/forum/viewto ... =28&t=3064
- Key fob battery change: http://www.kizashiclub.com/forum/viewto ... =12&t=2957
- TPMS re-learn, etc: http://www.kizashiclub.com/forum/postin ... 64&p=33533
- Plugging a tire puncture: http://www.kizashiclub.com/forum/viewto ... =32&t=3188
DIY Lighting:
- HID install: http://www.kizashiclub.com/forum/viewto ... =32&t=2861
- LED highbeam install: http://www.kizashiclub.com/forum/viewto ... =32&t=2900
- Osram 65w H7 headlight bulb upgrade: http://www.kizashiclub.com/forum/viewto ... =28&t=3070
- H9 fog light bulb upgrade: http://www.kizashiclub.com/forum/viewto ... =28&t=2919
- Access/aim fog lights: http://www.kizashiclub.com/forum/viewto ... =32&t=2329
- Disable daytime running lights (DRL): http://www.kizashiclub.com/forum/viewto ... =32&t=3012
- Remove L/R adjusting screw covers: http://www.kizashiclub.com/forum/viewto ... =32&t=2140
DIY Exterior:
- Bumper and headlight removal: http://www.kizashiclub.com/forum/viewto ... =32&t=2861
- License plate mount: http://www.kizashiclub.com/forum/viewtopic.php?t=3830
- GTS wheel rash repair: http://www.kizashiclub.com/forum/viewto ... f=32&t=844
- Self opening trunk with springs: http://www.kizashiclub.com/forum/viewto ... 879#p34879
DIY Interior:
- Steering wheel upgrade - http://www.kizashiclub.com/forum/viewto ... =28&t=3120
- LED bulbs - http://www.kizashiclub.com/forum/viewto ... =12&t=2556
DIY Suspension:
- Rear shocks and revised bump stopper: http://www.kizashiclub.com/forum/viewto ... =30#p40105
- RRM rear sway bar info: http://www.kizashiclub.com/forum/viewto ... =28&t=2977
- Front sway bar bushings and endlinks: http://www.kizashiclub.com/forum/viewto ... =12&t=3056
References:
- Alignment specifications: http://www.kizashiclub.com/forum/viewto ... 208#p10208
- OEM oil filter dissected: http://www.kizashiclub.com/forum/viewto ... =28&t=3085
- OEM air filter info: http://www.kizashiclub.com/forum/viewto ... 704#p31704
- Bulb replacement reference: http://www.kizashiclub.com/forum/viewto ... =12&t=2858
- Gear oil index: http://bit.ly/1w1QYkI
- OE and KYB strut and shock part numbers: http://kizashiclub.com/forum/viewtopic. ... 708#p38115
Common Problems:
- Pump noise after engine off (it's normal): http://www.kizashiclub.com/forum/viewto ... 250#p11250
- "Service Start System": http://www.kizashiclub.com/forum/viewto ... 104#p23104
- USB port fell into center console: http://www.kizashiclub.com/forum/viewto ... =32&t=2663
- Manual transmission shifting problems: http://www.kizashiclub.com/forum/viewto ... 161#p32161
- CVT noises and problems: http://www.kizashiclub.com/forum/viewto ... =12&t=3160, http://www.kizashiclub.com/forum/viewto ... =12&t=3158, http://www.kizashiclub.com/forum/viewto ... =12&t=2491, http://www.kizashiclub.com/forum/viewto ... =13&t=2813, http://www.kizashiclub.com/forum/viewto ... =12&t=1358, http://www.kizashiclub.com/forum/viewto ... =13&t=1579,
http://www.kizashiclub.com/forum/viewto ... f=12&t=649, http://www.kizashiclub.com/forum/viewto ... =13&t=1356
OE Suzuki Parts and Genuine Accessories Websites:
http://kizashiclub.com/forum/viewtopic.php?f=12&t=3911
Technical Service Bulletins (TSB):
- TS 0105223 Rear shock and bump stopper: http://www.kizashiclub.com/forum/viewto ... =12&t=3186
- TS 0210261 Extended cranking time: http://www.kizashiclub.com/forum/viewto ... 205#p10205
- TS 0210111R Reprogram CVT controller: http://www.kizashiclub.com/forum/viewto ... 207#p10207
- TS 0507013 Paint peeling: http://www.kizashiclub.com/forum/viewto ... 671#p20671
- TS 0312170 Immobilizer registration: http://www.kizashiclub.com/forum/viewto ... 671#p20671
Recalls:
- VG Spiders in evaporative canister vent line: http://www.kizashiclub.com/forum/viewto ... f=3&t=3203
- VL Automatic shift selector moved from P: http://www.kizashiclub.com/forum/viewto ... 149#p34149
Service Schedules:
- see attachments
2010-suzuki-kizashi-74865.pdf
2010 Owner's Manual
(4.92 MiB) Downloaded 2586 times
Kizashi_11-12_Maintenance_Normal_Severe.pdf
Suzuki Canada (normal and severe)
(159.77 KiB) Downloaded 1150 times
Servicing intervals Severe.pdf
Suzuki USA (severe)
(41.72 KiB) Downloaded 1227 times
Servicing Intervals Normal.pdf
Suzuki USA (normal)
(57.61 KiB) Downloaded 1213 times
Very nice work on both of the posts. I'll "desticky" the other posts so this will always stay at the top.
Well done.
bmw&kizzyownr
Thank-you, thank-you, thank-you for posting this. That's why I joined this forum to get valuable info from folks much smarter than I. Will print your summary and keep it in my car .... really, really appreciate it!
KansasKid
The maintenance guide for "Oil Change" leads to a thread titled: "Bumper Removal, Headlight Removal, and HID Kit Installation"
Also: The service bulletin for the ole "spider-in-the-fuel-vent" issue needs to be added.
Fixed.
If any further mistakes/ updates are found please include the relevant links. ;)
Very nice! I'll be using this quite a bit when looking up specs. :-)
sx4rocious
Good work! Thanks for taking the time!
FmrLCpl
I want to use synthetic gear oil for transfer gear box and rear differential.
But I could not find synthetic 80w-90.
Can I use synthetic gear oil 75w-90 instead? Any input?
2012 Kizashi SE AWD (purchased Dec 2012)
Blue Ext, Beige Int.
FmrLCpl wrote:- Transfer gear box (AWD): API 80w-90 GL5 hypoid gear oil; 0.9L (0.95 qts)
You should be fine with 75w90, as long as it's GL5. Other members have reported that dealerships used Mobil 1 75w90
