Any tricks to turning the engine to position a piston to top dead center ? Is there a nut on the end of the crankshaft that is accessible to do so ?
This is a Kizashi 2012 SE auto w/CVT
How to turn engine to get piston to TDC
You'll most likely need to remove the front RHS wheel and then get access from removing the plastic wheel well liner to the crankshaft pulley bolt. You'll also need to have the spark plugs removed and the trans in neutral.
I'm sure the process is covered in the Service Manual you can find here:
http://www.kizashiclub.com/forum/viewto ... =32&t=3192
Thanks ! I was searching through the service manual just now, and found a reference to the service hole you mention. Perfect !
Cheers.
Cheers.
2012 Kizashi SE
