problem
11zukizashi
I was pluggin in my car charger into the outlet closest to the radio, and i heard a pop and suddenly there was no power at this point, or at the radio, and my screen says service start system. I did some yoga and climbed under the footwell to check acc1 acc2 and radio fuses, but none looked burned out. What should i do...
I would replace the fuses, you can't always tell by looking. And it could be ANY fuse, not just those two.
Someone else had the exact same problem about three months ago.
11zukizashi
Thanks woodie, found the thread, double checked the fuses with a multimeter and problem solved!
11zukizashi wrote:Thanks woodie, found the thread, double checked the fuses with a multimeter and problem solved!
Here is the thread for future reference: http://www.kizashiclub.com/forum/viewto ... 104#p23104
Funny how so much depends on that one fuse... Make sure you carry spares :shock:
I'm glad you fixed this. In one of my Altimas, I permanently lost 3 of my lower fan speeds and two of my radio speakers. :(
I'd replace that car charger with a good quality one. This could have been much worse!
