Hi,
my car trunk does not open when using the key or the button inside the cabin. The only way to open it is to reach the handle from inside the trunk.
Is anyone here had the same problem and where should i look first?
Hope my english is not to bad. Thanks
Trunk release
Thank you for this! I missed the switch and found the info AFTER I had ordered a replacement latch. FYI the same trunk latch is used by Toyota for the Yaris of the same year. It’s available on Amazon for $30 cdn instead of $150 usd and out of stock or back ordered oem.
Interesting... The Kizashi also uses the same fog light as the Yaris of the same model years. I wonder what other minor parts they share.Czer wrote:Thank you for this! I missed the switch and found the info AFTER I had ordered a replacement latch. FYI the same trunk latch is used by Toyota for the Yaris of the same year. It’s available on Amazon for $30 cdn instead of $150 usd and out of stock or back ordered oem.
