Driver Seat motors no longer have power?
chase24870
Hey everybody,
My kizashi SE's driver seat motors have stopped working, none of the controls work. I've pulled the seat control module that's on the side of the seat and everything is plugged in correctly, then I looked under the seat and both wiring harnesses are plugged in. Surely both the lower and upper seat motor's couldn't fail at the same time, so its likely a fuse or something right? Has anyone else run into this problem?
I wanted to check here because the dealership wanted to charge me 180$ just to look at it, so I'm gonna try and fix it myself.
Thanks lads
The fuse would be the first thing that I would check. Even before the connectors.
Speed_Racer
I'd start by checking fuse #8 - passenger side fuse box
Beeman1019
My 2010 has power and ground to the seat, however the seat does not move when any of the controls are moved. Could it possibly be the power is broken in the module after the power input ? And how can I check that ?
The seat harness to control switch is a problem area. I would take a peek there.
Beeman1019
Being a basic no nothing about this, where exactly would the harness be located.
Beeman1019
old tech wrote: Wed Apr 21, 2021 11:19 pm The seat harness to control switch is a problem area. I would take a peek there.
Where can I locate that , under driver seat ?
At the control switch. Remove that side seat base trim panel.
