TPMS ID NOT REGISTERED - how to fix?
FmrLCpl
2012 kizashi SE AWD, CVT, around 50000 miles.
The '!' mark is blinking, the low tire pressure is on, the message says "TPMS ID NOT REGISTERED".
does anyone know what is it and how to fix it?
2012 Kizashi SE AWD (purchased Dec 2012)
Blue Ext, Beige Int.
http://www.suzuki-forums.com/suzuki-kiz ... tid=350301
That's how you put your car into "relearn" mode for the TPMS sensors. You can put it into relearn and then let five psi out of each tire to get them to send a signal that the car will synch with. SamirD has a thread here about TPMS but it's a 26 page saga. It contains everything you ever would need to know, but will take half a day to read through. LOL
https://kizashiclub.com/forum/viewtopic ... hilit=TPMS
It's worth a try to just relearn all of your sensors, but I suspect that if it was working fine and then lost synch that one of your sensors is bad.
I would try the relearn procedure. The one on suzuki-forums is not exactly correct on a few of the steps like the flashing will be simply continuous, not in 2 second flashes.
