replacement of the meter's backlight
- SAEED_KIZZY
Kizashi odometer and most of new cars use SMD LEDs for backlight soldered on PCB it is hard to disassemble odometer and then soldered new LED on it but if you want to do that goto serivce manual on "combination meter Removal" section.campus23 wrote:Colleagues how to remove and repair the meter's backlight? my backlight glows less and less all the time. It can be fixed somehow
https://avnet.ws/kizashi/
Also there is a Brightness control knob in cluster that you can use to adjust brightness(in case you don't know).
