what wheels and tireS are you running
Post some pics of your setup........sciraddo wrote:I'm running 9's in the back and there is no rubbing issues providing you get the right offset. 18X8 with a 1.25" lip up front and 18X9 with a 2.5" lip at the rears. Both front and rear offset of + 38. Just ordered some H & R Springs for the car with a 1" drop all around, which should give a a slight negative camber. The car should sit nice once the Spring are installed.
2011 Black Kizashi SLS - DD
- EBC Brakes
- 10% tint & debadged
2015 White Jeep Wrangler Altitude - Wife's ride
2004 WRB Subaru Impreza WRX - Garage queen
- EBC Brakes
Well, I've owned 13 VW in the past and most have had H & R springs or coilovers of some sort. It's what I know and I've never had any issues with them and depending on the set up they give a relatively comfortable ride and decent handling. I don't know anything about the RRM Springs. I paid $290 for the set, shipped to my buddy's shop.cca105983 wrote:Just out of curiosity sciraddo, What would you say the difference is between the H & R's and the RRM Springs? Why'd you choose those?
I have a front wheel drive Sport Kizashi and I didn't want a really aggressive drop and H & R makes a 1" drop all around for the FWD. For the AWD the make a 1.4" drop front and 1.3 drop at the rear or is that the other way around. H & R said they will not work on the FWD's.
Stock 18's with Falken Azenis PT-722 235/45/18 they are 60K life tires and are $168 a tire. My OE tires only lasted 12K and The alignment was bad from the factory. The dealer gave me a new alignment under warranty, But wanted to charge me $255 per tire and Suzuki wouldn't do anything to compensate me for the bad alignment.
So screw Suzuki customer service. I can get these Falkens for less with over twice the warranty.
- Contact:
im on the stock 16" dunlops right now... saving up for some 17's or 18's very soon!!
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
IG: N2OKizashi
does anyone know if 18X8.5 ET+35 will fit on kizashi??
I found this link really helpful, check it out. But you need to know the offset of the set of wheels on your car.
http://www.1010tires.com/WheelOffsetCalculator.asp
Northernstar wrote:does anyone know if 18X8.5 ET+35 will fit on kizashi??
sigma008 wrote:here are my 22 inch wheels.....no scrub, no rub, no modifications.....
Hey Man have you tested your ride with a full trunk and passengers in the back. I like the way yours look and I wanted to make sure that it does not rub or scrap before I make the investment.
