my gas vs your gas
Yes, I wouldn't say a higher octane spec than the minimum is wasted (and it certainly doesn't go out the exhaust pipe- that's for sure!) :)
~tc~
It's "simple combustion thermodynamics".
Octane is the resistance of the fuel to detonation. In other words, higher octane fuel has LESS energy than lower octane.
In a traditional combustion engine, however, compression ratio can more than overcome this. (I sum it up as "compression ratio cures all")
You want to use the LOWEST octane that will not experience ping/knock from predetonation for max power.
davidbus159
I recently read that Shell was the only "top tier" fuel available in my area, so that's all I use now (87 octane). Here's what influenced my decision: http://www.toptiergas.com/
12 Kizashi GTS
10 Kizashi SLS
07 Charger R/T
05 325i
03 Cooper S
00 Civic Si
95 Sebring Lxi
93 325is
86 325es
87 Supra
83 Celica GTS Liftback
76 Corolla KE35 body
