Crack in engine block
masch
Hallo,
do you ever seen a crack in the engine block of the 2,4 liter motor??
It is not the engine of my car, i ask in name of a friend, who has the same engine in his New Grand Vitara.
I never heart about this problem in Germany or Europe.
Thanks for your answers.
Greetings
masch
Sorry, my English is not so good, but i will do my best.....
That is the first time I have ever heard of a cracked engine block with this car.
It was cracked without performance enhancements?
masch
Hallo,
he only has seen a little bit of water under the car.
The mechanic meens, thats a very often problem by 2,4 liter SUZUKI motor.
No one in Germany ever heart this, i cant believe , that this is a real problem of the engine.
His engine has 50 000 Km , is 5 years old.
Many thanks for your answers, and sorry for my Englisch :cry:
Many greetings
masch
Hallo,
i must correct my post : the engine has 90 000 Km --- or 56 000 miles
Greetings :drive:
Does the workshop know what they're talking about/ looking at? If I was the owner, I'd be a bit dubious until I saw the block cracked for myself.
That engine has been around for a while now, so it shouldn't be too hard to find other cases (if it is a common problem.)
coref1
There's no evidence of that type of problem on this forum and a quick google search didn't come up with any further evidence.
sx4rocious
there are a few examples on this forum of members that run their cars pretty hard and (like myself) are a bit lacking in the service, and I have yet to hear of this problem. Same with the SX4 guys as I believe the 2.0 and the 2.4 are the same blocks, just different heads.
Suzuki Esteem got the "J" engine back in late 1998, that was basically the same block. Never heard of any cracking. Early Aerios (J20) spun rod bearings and threw the rod through the side of the block from time to time.
Hi Masch, I put a post on that Suzuki forum that I linked to earlier. If there are any common problems they will surface from that forum. (I hope you don't mind I've cut and pasted your posts?)
Here's a link so you can monitor the replies http://www.suzuki-forums.com/2g-2006-gr ... post595954
