Would have to research more, buy and test.
Does anyone have any experience with these?
Unfortunately all I have is the listing itself (click on the picture). Other than that, I will be researching more as well.murcod wrote:Nice.
Have you got any more pictures - in particular of the brown plug's contacts/ pin orientation? (I've got a whole stack of info on my PC somewhere about those plugs, plus my head unit is sitting around so I can check against it.)
Actually, my goal with this part is to keep the stock USB port and be able to use it with an aftermarket stereo.KuroNekko wrote:I recall seeing some kind of connector at the base of the USB port circuit board when I fixed mine.
Check out these photos:
http://kizashiclub.com/forum/viewtopic.php?f=32&t=2663
Also, don't you want a USB female end assuming you are looking to replace the factory USB port?
And bought.murcod wrote:Nice.
Found a pic - if it looks like this on the inside then you've got the right plug http://www.kizashiclub.com/forum/downlo ... hp?id=1531
At a guess, is it a part made to fit a WRX? I discovered they used the same type of plugs.
Argh!murcod wrote:![]()
Can you cancel that purchase Avluis?
I just found this: http://www.sonicelectronix.com/item_686 ... USB-2.html
It's the wrong pin configuration going by the above.
There's also this one, but I'm searching for a pin out of the plug at the moment:
http://www.sonicelectronix.com/item_614 ... OYUSB.html
