P0443 Code
I have finally started to do all of the standard maintenance that I haven't done yet. I was getting the P0443 code at least once or twice a week for quite a long time, I hate to admit. I changed the spark plugs two weeks ago and this code (nor any other code) has popped back up. I went past the 60,000 mile interval to change the plugs and I should have delved into the standard maintenance much sooner. I believe the engine had 83,200 miles on it when I changed the plugs. I just wanted to pass along how this code was resolved for me knowing that the Kizashi can have quite a few gremlins with the codes.
P0443 has to do with the purge valve back by the gas tank. If it stopped when you changed the spark plugs that was pure coincidence. Might have just been a loose gas cap, but this whole system is subject to a recall.
viewtopic.php?f=13&t=5144
Woodie wrote:P0443 has to do with the purge valve back by the gas tank. If it stopped when you changed the spark plugs that was pure coincidence. Might have just been a loose gas cap, but this whole system is subject to a recall.
The odd thing is that I had the recall done back in the summer and I still kept getting that error code
