I was just curious if these rims would fit out kizashi. 19"x9.5, 5x114.3, +42 offset. My biggest concern would be how much room do we have with the suspension components with the stock wheels. with the new offset it will be just over 11mm closer. Do we have more room then that?
thanks
question if you think rims would fit.
Tire Rack site is very useful. Plug in your vehicle type and do the rim search in the diameter you're after- then check the rim widths and offsets they say will fit. It will give you a rough idea on if it's possible. IMHO the 9.5" width is going to be a huge problem, both from the suspension clearance/ guard clearance aspect and finding a suitable size tyre that will fit on a rim that wide.
