Independent fog lights (fogs without headlights)
NA models (and possibly others) of the Kizashi are wired in a way where the fogs cannot turn on unless the headlights are also on. Many other car enthusiasts have bypassed this restriction, so I thought I would create a thread for any of us that are interested in doing this.
This thread that has some information: http://www.kizashiclub.com/forum/viewto ... f=13&t=589
Also, ms_enj has been kind enough to share wiring diagrams, but I am unsure if these are for NA models:
If I'm reading the diagram correctly, the fog switch will trigger the fog relay only if the taillights are on. We need to bypass the taillight relay by connecting the red/yellow wire from the fog switch and the red/blue wire leading to the fog relay.
In the case of NA models, I'm assuming the headlight relay is used instead of the taillight relay.
Fog Light Circuit.pdf
(64.08 KiB) Downloaded 393 times
BxKizashiS
I don't even have fogs :-(
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
Dthrill_08
I bought a fog set on Amazon that was original ( or very similar!) It brought the black tape to hide wires and all. It looks similar to the non Fog light kit I had. It even came with a button to put next to the traction control button
