114 days; Part II
Kizashi-flying, tires howling. Time for summer's tires. Wonder what I'll actually do.
There are strategic corner whoops now that permit one so inclined to get one side of the car COMPLETELY up in the air.
95,902
DEFINING INSANITY:
I've owned Kizashis since Dec 23, 2010, which means for 2,131 days I've averaged 113 miles each.
-2,131 days
-241,353 miles
But, there are no underbody panels left on this one...... :roll:
95,909
I didn't think you had any left on the first one either...
I did have some left on the old one but they were mere remnants of their original configurations :mrgreen:
Last tank 26.1 MPG
96,064
Heard crackling from the right-front-door speaker with the stereo off when backing up or moving forward slowly, but it did not duplicate this morning. Hmmmm.....
Hit two holes yesterday; ugh.
Last tank 26.9 MPG.
96,855
Well I gone and done it; I bought new tires --gasp!-- not used, for the Kizashi.
I was shoppin' around craigslist, using a $250 cap, when I decided to google my size (225/50 R17), and discounttiredirect had some Chinese "Sentury" UHP W-rated XL skins for $64 each. Did a quick review search ("...good in dry, not as good as some in the wet"...).
And they only weigh 24lb.
Set's on the way.
We'll see 8-)
Last two tanks Gulf premium both returned 31.4MPG. Warmer.....
97,515
The folks at DiscountTireDirect.com called to let me know my new tires won't be here before May 6, so I'm sliding around on my bald Toyo snows until then........
Gas mileage is hovering in the 29--32MPG range!
98,448
Tires will be here this week.
Still need:
-plugs
-all fluids replaced
-upper rear shock mounts
-windshield (and wiper blades)
-figure out the stereo issues
Great gas mileage now.
98,800
Tires go on today; actual weight 23lb each.
I washed it on the way in, especially the mud out of the wheels. They like that (the guys doing the work).
99,466
My my my........
So my $64-each tires are quiet. They currently (at 42PSI front, 40 rear) exhibit no 'set', nor 'unwind'. They certainly grip. While I've had little opportunity to push them in the wet, the bit I've done suggests they're at least safe.
Further testing required.
Last tank Gulf premium 27.0 MPG.
99,766
